DSDP Don wrote:
Wow.....this thread is really all over the place. "donfrump" brings up a good point about people making disparaging remarks about something they can't afford. This really makes their opinion useless because it's so slanted.
Agreed, but as I just noted to Don, what I described was not 'slanted' really at all, 'cause I was able to afford the diesel pusher we were looking at. This was a 2015 unit that was just about to turn a year old, had been a demo unit, so they just knocked over $100k off the price. It was within our reach, financially, but it ain't in our driveway, 'cause I don't like that lack of throttle response. :)
Large displacement diesels in motor homes and semi's are not designed to have the "pedal put to the floor". When you do that with a diesel, it will fall on it's face.
Yep, indeed they will, which is why I prefer my V10 gasser, and the 'roar' and immediate throttle response I get when I put the pedal down on it. I like knowing that the engine can do that, and can get the unit moving quickly, if I need it to. Really exasperating to me to push down on the pedal and nothing really happens but a lot of grunting.
I realize, these are massive RVs and not meant to be drag racers. However, I still prefer an engine with some throttle response that can get things moving quickly if the need arises (like, merging onto a freeway, getting out of someone's way that isn't paying attention, etc).
They're designed to have the power rolled on. If you roll it on slowly, it will accelerate like other motor homes.
Right, because diesel burns slower than gas, and as a result, a diesel engine will struggle to accelerate as quickly as a gasser can. A gasser can drop down a gear, briefly turn 5000 RPMs and really get you accelerating quickly. That is something a diesel will never be able to do. It can't downshift, all it can do is grunt and grind along in high gear, low RPMs. Results in better mileage and longer life, possibly, but takes away ability to accelerate quickly like a gasser can.
If you drive down a smooth highway at 65 mph, both a gas motor home and a diesel will ride smoothly. If the road is full of potholes, both a gasser and a diesel will ride roughly. The diesel may absorb the shock a little better because of the size and weight, but you'll still feel it.
I had a gas motor home with the 8.1 Workhorse and it was a diesel eater. I could blow by most diesels on any grade. Now, the noise was horrendous in the cab, even after adding a lot of installation, but you only climb grades during about 5% of your travels, so not a big deal.
A diesel is more complicated to operate and maintain, but can haul and tow more weight. You need to decide what you want to do your coach, how often you'll use it and do you have a need for a diesel. Modern day gassers are very capable and probably the best choice for those who don't do more than 8-10K in miles every year.
My sister just took delivery of a new Fleetwood Southwind today. They were done dealing with the complexity of a diesel pusher. It's actually 4" longer than the diesel they sold and is just as nicely outfitted.
Good luck on your search. The lines between a diesel and a gasser have really been blurred so it's a tough choice.
..With all that, I agree. Especially how the lines between the two have really blurred and made the choice tougher. :)
Will
