calfman47's avatar
calfman47
class a slidout
My slide out is out of square, its tight at the top and wide at the bottom the same for the other side but wide at the bottom and tight at the top.
It has some level adjustments that I have tried but with no success.
anyone had issues like this?
My slide is the kind that raises up a couple inches on rollers before it comes inside.
1 Reply
  • I had a problem with mine. Mine has gears on a track and I pulled the slideout all the way out and realigned the gears. Now this is a job because you have to knock the pins our of the gears to relign them and have no problem since them.
