Wannabango's avatar
Wannabango
Class C without boondocking amenities
I'm considering getting a Minnie Winnie 22R to travel around the country while working remotely. It's the smallest class C that Winnebago makes while still having plenty of room for a single guy. I like the idea of getting a Winnebago because they're so highly regarded by the community. I'll stay at my destination for at least a month or so at a time. I don't need the propane system, I can easily get by without it when I'm on the road. It just seems like a waste to have a propane system and all of those propane appliances that I don't really need. Is there an alternative that better suits my needs?
  • I'm not sure what your goal is in searching for a propane-less RV. If it is to save money, and assuming you could find such an RV, you'd have a heck of a time selling it. I'm not even sure you could give it away. If it is to just live an amazingly rugged life style then just don't fill the propane tank.
    On the other hand you could just go with the flow, use the fridge to keep your beer, submarine sandwiches and ice cream cold (parking lots are plenty level enough for the fridge), and have a hot shower occasionally. I've had my RV for 3 years and have only refilled the propane once. I rarely use the stove top but I use the hot water heater, the fridge, and sometimes the furnace.
  • Old-Biscuit wrote:
    ....travel around the country while working remotely.
    I'll be staying mostly at Walmart parking lots overnight
    So in other words you plan on 'stealth' camping.......no CGs. Parking lots only
    No electric hook ups. Basically a vagabond----slumming
    So it would sound like PROPANE would be beneficial
    I'm sorry, I wasn't very clear. I meant to say that I'll be staying at Walmart overnight when I'm on the road between destinations. My destinations will have full hook-ups and local internet
  • Anonymous's avatar
    Anonymous
    Approved
    The more dry camping, in your case, the more Wallydocking you do the more you'll need your propane appliances. Going without a fridge is nuts. What benefit are you going to derive by getting rid of your propane appliances?
  • Wannabango wrote:
    I'm thinking I'll just cut out foods that need to be refrigerated.
    Pretty spartan living. Presuming your post isn't a put-on, I think I'd keep the propane system in case you miss butter, eggs, meat, pop, beer, milk, ice, salad, juice, mayonnaise...
    It's usually not difficult to find level spots in WM. And there's no law saying you can't use a leveling block.
  • ....travel around the country while working remotely.
  • 2oldman wrote:
    Propane is not a 'boondocking amenity.' How will you cook? How will you keep the fridge cold when traveling?
    I have a small butane stove that I can use while on the road. I'm thinking I'll just cut out foods that need to be refrigerated. I'll be staying mostly at Walmart parking lots overnight and you're not allowed to level your RV there, which may be necessary to run the fridge safely without damaging it.
  • DrewE's avatar
    DrewE
    Explorer III
    I'm not aware of any class C's, particularly smaller ones, that are "all-electric" (which, for RVs, basically means no propane; often there's a diesel fueled heating and hot water system in so-called all-electric RVs).
    I think you may be misjudging how little you'll need propane. The stovetop is propane only; are you planning to cook only with a microwave? The water heater, if it has an electric element, is quite slow heating on electric only. The furnace is propane only, though electric space heaters or heat strips in the air conditioner can be used in relatively mild but cool temperatures to keep things warm. That much, at least, may be entirely practical in some parts of the country (including Texas).
  • Propane is not a 'boondocking amenity.' How will you cook? How will you keep the fridge cold when traveling?
