FIRE UP wrote:
et2,
Based on your statements of the "Main" radiator, "behind the fan" is to me, a bit off some. You don't say what kind/make/model coach you have but, normally, the unit directly facing the fan is the CAC or, Charge Air Cooler for the compressed air that get's warmed up as it's compressed by the turbo.
Then, what you see when looking at the back of the coach IS, the ONLY radiator, not the "main" radiator. I'm not chastising you here, just helping you with some terminology, sort of. You are correct in the fact that many, many coaches are pretty much IMPOSSIBLE to actually do an efficient and accurate job of cleaning both the radiator and the CAC without removal.
Yes, there will be some that say they can do it and, it's as good as removing the two units. Well, to those, I commend them. I too cannot almost even see the fan-side-face of the CAC and certainly the that same side of the radiator.
About 4 years ago, I pulled both of them at home. Not necessarily a fun job but, very informational. Based on the fact that the previous owner had the incorrect amount of oil in the engine which, contributed THROUGH an incorrectly placed slobber tube, to a very, very dirty CAC and radiator that, there was only one way to get both clean, REMOVE THEM!
As stated, pulling both of them is not a fun job. Semi-goofing around, it took me about 6 hours to pull both. Now, knowing what I know now, I'd say it could take me as little as about 3 and both would be out. But, since I now run the correct amount of oil in the engine and, the slobber tube has been extended all the way to the back end of the coach, I don't have to worry about it nearly as much.
I have an inspection camera, one of those that has a 3' lens, and I probe it way inside the fan shroud and can take an annual inspection with that camera and see if there's any buildup from regular road debris/dust/etc. So far, in the almost 4 years of running and about 25,000 miles, they're both very clean.
Scott
The radiator behind the fan is the CAC? Then did have it wrong ( if this is the case). The one at the back ( standing facing the rear grill) of the coach is the "main" engine cooling radiator? Ok then I probably cleaned that fairly well. But the CAC is not accessible by me. I'll have the Cummins people give me an idea on cleaning costs.
The air coming out the back when the engine was started seemed strong. I'm certainly not a mechanic, however I'll try to keep up any and all preventive maintenance if possible. I just don' t have the place, time, or a bunch of tools to tackle things like this. I commend those who can go the extra mile fixing things.
2013 Fleetwood Expedition 40x - 360 ISB -
