Blackdiamond wrote:
JumboJet wrote:
Waterless Washing
I haven't tried this costly product yet, but have been reading up on it.
I actually was able to wash my RV at a city owned RV park in Washington State and the park attendants loaned me the bucket and brush.
I have used this for a couple years, works great.
Waterless washing is only good for very light cleaning, like a light dusting. Use it for anything else and you're scratching it. I'd never use it.
Dirt particles need to be floated off and even then you have to remove particles from your wash mitt frequently. If you don't you're adding tons of swirl marks. In the link provided spraying the solution on the mitt does NOTHING for preventing swirling or encapsulating dirt, it has to be sprayed directly on DUST to encapsulate. Never good for anything more then dust.
Bill.Satellite wrote:
gemert wrote:
One of you mentioned truck washes. I've been told that their chemicals are too strong for RVs? True, myth? Whats the real deal? Thanks
MYTH!
For those who think the coin operated car washes or truck washes are fine, well they are if you want to remove all the wax protection you have on you RV as they use harsh chemicals that strip off everything. The cleaning solutions are just too harsh for waxes and sealants. You need a PH balanced washing soap to keep your wax and sealants. PH balances soaps tend to be more expensive. Mequiars gold is the cheapest PH balanced soap you can get.
I use the old 2 bucket method. I have a wash mitt on Shur Line extendable pole( going to be switching to a Montana Boar hair brush soon) . First Rinse the sides and wash off any large particles, then hit the coach with a Gilmore Foam master and let the foam lubricate and wash particles down the side. Then it's wash with the mitt and extendable pole. On the road I can do the whole coach in about 30 minutes after set up. .
We can usually end up at a campground at some point that allows a wash or has a specified wash area.. Other then that I don't want to put swirls marks all over.
