crasster
Dec 21, 2016Explorer II
john.d.dobbs wrote:
We have a 2008 Winnebago View 24H and we're on the road this week. The 5 red lights along the top rear of the RV - clearance/tail or lamps (or running lights) are not lighting. I believe they are supposed to be lit when the engine is running or at least while the transmission is in gear. Brake lights and turn signals are working fine.
I first started searching for fuses under the drivers seat and then under the drivers side foot area. There are lots of fuses there with no clue as to what they are for - I don't seem to have a fuse panel diagram.
I did find the automotive and coach circuit breakers under passenger seat and there is a breaker there marked CLEARANCE/TAIL LAMPS but that appears to be Ok.
Any other hints as to where I might look for the cause of this problem?
Thanks,
John
On the back of each fuse are two small exposed prongs. You can get a continuity meter and check each one without pulling them. If you find one blown, there may be your problem.
38,782 PostsLatest Activity: Aug 30, 2026
