CharlesinGA
Dec 21, 2016Explorer
CharlesinGA wrote:
Do the lights work when you manually turn on the lights with the switch on the stalk?
I'm guessing the NCV3 chassis is like my slightly older T1N chassis in that there are three fuses for Daytime running lights (DLR) and those are the LH head light, RH headlight, and the running lights. Yes, MB includes the running lights in the DLR circuit. You can, on mine, pull these fuses and not affect the normal operation of the lights via the headlight/parking/running light switch on the stalk, those are separate fuses.
I removed the three DLR fuses and when I need lights I manually turn on the lights with the switch, just like I do with my other cars. Saves bulbs from burning out so often. On mine the three DLR fuses are located in the drivers seat base, outboard side. The legend to the fuse panel is on the inside of the access door to the fuses.
Charles
2007 Winnebago View 523H on a 2006 Dodge (Daimler-Chrysler aka Mercedes) Sprinter 3500 chassis (T1N). Bought Sept 2015 with 18K miles on it, Prog Ind HW30C, Prog Dymanics PD4645, Chill Grille, PML/Yourcovers.com deep alum trans pan, AutoMeter 8558 trans temp gauge, Roadmaster sway bar, Fantastic Ultra Breeze hood, added OEM parabolic mirrors and RH aspherical mirror.
38,782 PostsLatest Activity: Aug 30, 2026
