I pumped out the tank and then i pulled the plug on the tank sump and draind the rest,I went back to the water seperator and drained it and and took the line loose at the seperator to the tank and blew out the line back to the tank.What do you think. Should i fill the tank with water and drain and let air dry for a while.
