JackEnloe wrote:
I have a National Tropical 2004, 38' that I have to actually drive all the time. I have been reading about the steering stabilizers of which I think I like the Safe Steer best. I called Camping World to talk to them about this product and if they could get it for me. Immediately the person told me that in his experience he would think the problem is in the rear stabilizer. This is something that surprised me.
Has anyone solved the "wander" by replacing the rear stabilizer? I want the motorhome to be easier to steer but don't want to spend money on something I don't need.
Interested in your opinion
Jack
Jack,
Well, as usual, advice given by Camping World leaves less to be desired. Wandering, especially in motor homes, can be caused my a multitude of things. First, check all your tire pressures. Too much tire pressure causes the tires to be "mislead" by all the imperfections in and on, the road. If and when you check them, the smartest way to go about it is, GET THE COACH WEIGHED.
Then, get on your computer and find the tire chart that applies to your tire manufacturer. Then go to your particular size/type/model of tire and see what they recommend for your tire pressure, based on the axle weights you came up with.
Now, once that's done, alignment is next on the agenda for attempts at correcting steering and wandering problems. If at all possible, try and get all four corners weighed to see what, if any, are the differences between the front two corners and, also the rear two corners. If there's significant differences and, it's possible to maneuver some of your loading, then that will help with better balance between the right and left side of the coach. If you can't or, have no way of balancing things out, then you have to live with it.
Another thing that actually co-insides with alignment is, wheel bearings. Do make sure that both front wheel bearings are tight or, I should say, "Properly adjusted". Any loose bearing situations are magnified when the loose side tire is running down the road. You see, when bearings are loose, the tire loses it's ability to "track" straight and therefore, will wander because it has less control.
The next items are steering components. You'll have to make sure your tie-rod ends are snug and not worn, ball joints,(if you have them) need to be within specs too. Another words, make sure all your components up front, THAT ARE FACTORY INSTALLED, are in good working order.
This MUST be done, before starting to THROW money at any after market equipment. I don't know how many miles you have on your shocks but, if they're worn, the body can lean a little here and there and therefore, that has influences on the suspension which, also has influences on steering and control. This means checking any "anti-sway bar components too. Many times, the bushings on the factory ones are rubber and, they get really squashed and severely worn or, even disappear due to age and mileage. That will cause some handling issues too.
Now, once you're completely satisfied that all front end components, steering, bushings, shocks etc., alignment, tire pressures are all up to snuff, then, and only then, you can move towards the rear of the coach to see what can be done back there to possibly either correct or, enhance handling performance pertaining to the front end.
So, hope this helps some. Throwing money at after market products prior to getting factory settings into correct specs, is not very smart in my book. Just an opinion here, good luck.
Scott
