aboeck3
Nov 17, 2014Explorer
cold weather travel
I am traveling from a warm Florida to a cold Missouri. If my tires are at the correct psi when I leave Florida do I have to check and add air when I get into cold weather?
rgatijnet1 wrote:hipower wrote:rgatijnet1 wrote:
Reading some of the posts it is becoming very clear why some people have trouble with their tires. Of course, according to them, it is always the manufacturer's fault.
Maintaining proper air pressure at all times seems so basic and so important that it is preached by every tire manufacturer.
The problem with changing pressures is accelerated by our desire to maintain the ideal pressure for the weight being carried.
If we follow that thinking then adjusting the pressure every time we stop or the temperature goes up or down a few degrees would be the norm.
Running tires underinflated is asking for trouble in most cases. Those of us who run higher pressures than the supposed ideal based on weight will rarely see pressures drop enough due to temperature decreases to become a factor. If we as RV owners are anal enough about maintaining ideal pressures we would be stopping frequently to check the pressures and adjusting for low pressure as well as high pressure. I see drivers adding air, but have never seen anyone removing air because the pressure increased due to higher temps.
I guess you forgot what the topic was about....Driving from Florida to Missouri. When the topic was started, the temperature difference was in excess of 60 degrees at those locations. In that case the pressure drop would have been close to 16 pounds.
If you travel during the Winter to locations where the temperature has big swings, like in this topic and in the Western mountains, then you SHOULD raise or lower your pressure accordingly. Keeping with the topic, if someone during that same period of time traveled from Missouri south to Florida, and their tires were properly inflated in Missouri, then they would be 16 pounds over-inflated when they reached Florida. It seems obvious what you would do, which is drive around with grossly over-inflated tires because you have NEVER seen anyone remove air from their tires.
Some of us that do travel in the Winter and visit areas where we experience big temperature swings, do check our tire pressure each morning and adjust accordingly, either up or down. If you have never seen it being done it is because you don't travel to those areas or travel during very cold Winter temperatures.
