oldmattb's avatar
oldmattb
comparing our coaches - read only if you are bored
While driving back from New Mexico a few days ago, I was thinking about the good and bad of the three motor homes I have owned. This is just a bunch of random thoughts, so don’t take it all too seriously.
Safari Trek 2600 Isuzu
Good:
This thing would go anywhere and get you back. Relatively short wheelbase and high ground clearance. We took it on the full length of the Apache Trail, and down a lot of rough dirt roads. The Isuzu engine and Jatco transmission were bullet-proof.
Honest 12MPG towing a small car
Low-maintenance Filon roof – a coat of marine enamel after a decade
Aluminum body – very durable
The exhaust brake was amazing – it would slow the coach to walking speed on a 12 percent grade
Good cabinets, good storage for a little coach
Could park it nearly anywhere
Nothing ever broke.
Very car-like in maintenance requirements
Tires that one could actually move around, if you could loosen the 2 zillion lb/ft lugs
Long-gone dead cruise control
Bad:
15 MPH up steep hills
My 6-foot body in a 6-foot bed
One had to really “operate” it on hills – downshift, downshift again when the pyrometer rises, watch the trans temperature, get a running start on hills, look for passing lanes in heavy traffic, etc.
Brutal ride, even with suspension modifications
Small towd car really means small – 2000 pound towing capacity. Auxiliary braking was required!
Original issue sofa and dinette were apparently made for children.
Fuel gauge sender was a square tank type in a cylinder tank. The last quarter tank went by in about ½ hour.
Foretravel Grand Villa 1994
Good:
Honest 10 MPG towing small car
Amazing quality of cabinetry and general build quality
Lots of storage for a non-basement coach.
Fiberglass roof needed a coat of paint and then good for another decade.
A rocking-good dash air
Big, fat, thick steel bumpers – actual bolted on functional bumpers
Automatic lights in cabinets and closets.
I really liked the central vac, especially after I replaced the unit with a concealed shop vac.
A doorbell!
Lighted entry handle was just so cool!
Bad:
Ours had a suspension clunk I could never remedy
When the suspension begins to sag, the Torsilastic suspension re-do gets expensive if the shims have been used up.
Small shower for a big coach. The door is always cold when it hits your butt!
Our exhaust brake was not integrated into the transmission – manual downshifting on hills.
We loathed the original-issue pink, magenta and brothel décor.
Tiny starting battery holder required two side-mounted gel batteries to start the engine properly
Propane generator – parts obsolete
Gelcoat outside looked shabby pretty quickly without care.
Low to the ground – had an aftermarket cage to protect transmission, which hit bottom several times
Air governor was very hard to replace.
Outside storage bins opened to about 90 degrees.
Water pump seized, hydraulic pump failed grandly, Allison computer failed suddenly.
Intermittent cruise control.
Despite size, layout in front seemed cramped.
Monaco Windsor 1998
Good:
33-foot is a good length and has a smart layout for no slides.
Full body paint still looks great
Good storage
Outside bins open to almost 180 degrees
Good cabinetry – slide-out pantry is nice.
Nice and big shower!
Ducted AC
Storage under the bed! Good use of space.
Thermo windows
Sofa is actually decent fort sleeping.
Best front curtain system – easy to use.
Good design for doors to separate bath and bedroom from front of coach.
So many interior lights!
Solid surface counters and good fixtures
Big water and waste tanks – we have yet to run out after 3-4 days of dry camping
Will tow just about anything. Same little car is not noticed!
Big, quiet diesel generator
I like the front-entry – I think it reminds me of the school bus from when I was a kid.
Air bag suspension – I don’t understand it yet, but I like it.
Ice maker in fridge is nice, but we never seem to take advantage of the ice.
Fully-functional cruise control!
Bad:
EPDM roof requires maintenance and inspection
I worry about that complex thermostat system for AC and heat failing
Water line to ice maker failed, flooding coach. Should have been copper! (was a good time to install hardwood!)
That front TV is a target for hitting head
Huge windshield is like a terrarium.
Less sitting space than previous coach.
Don’t know MPG, don’t want to know.
Inverter sucks the batteries dead in a few hours.
Dash air and heat seems anemic
Matt B
