classctioga73's avatar
May 30, 2016
confused about my RV house batteries
my 2000 31w Tioga SL RV has two house batteries underneath the steps as you enter thru the coach door. they are two "Everlast trolling motor and RV battery".
24DC, 85AH, 125 RC (reserve capacity)
this weekends trip to Lassen N.P where generator hours are only 8-10am, 12-2pm and 5-7pm. I ran the generator for those hours. It was kind of cold up there so we used the heater that runs on the house batteries. the heater stopped working at about 2am with it set at 66 degrees. we used only one to two lights after 8pm and used the pump as needed for restroom use. the fridge was set to auto so i assume it also uses DC from the batteries.
are my batteries bad? shouldn't they hold a longer discharge?
with the two batteries in parallel does it mean i get a total of 250 minutes of reserve capacity (125x2= 250)? are these the wrong type batteries to use? which are the best to use? would using the generator for longer time to recharge the batteries done the trick?
please help.
