luvdoggiez's avatar
luvdoggiez
Coolant tank for Allegro bus
Hi there everyone,
DW and I have a 2003 Allegro Bus motorhome. Just inside the grate for the engine compartment is a Plastic overflow tank for the radiator. It has sprung a leak just above the Minimum line on the tank.
I understand this can happen to these tank because of the UV rays they are exposed too. Does anyone have any idea where we might find a place where we won't pay an arm and a leg to get a replacement one of these tanks. I've tried looking at ebay and Amazon and haven't found anything. Any suggestions would be greatly appreciated.
Thanks!
Happy Camping! Eric and Carol Anderson
  • Plastic will get brittle and bust. I dropped a plastic container one day and it shattered like glass.
  • Hi everyone,
    I tried using the JB Weld 'Marine' on the tank and it failed shortly after the engine got hot. I guess we should have tried the JB weld 'High heat'. The only problem was, it said nothing on the label about working on 'Plastic' Oh well.
    I'll be calling Sacramento Truck center (Freightliner dealer) about getting a new one. I was told all i have to do is provide them a VIN and they can figure it out for me.
    I'll keep you posted!
    Thanks! - Eric -
  • Our 2002 Frieghtliner/CAT had the same issue. We ordered a new one from Frieghtliner and the last time we were in Gaffney they changed it. We figured it was good insurance to have it done before it broke wide open.
  • Hi there Everyone,
    Here is what the tank looks like. Anyone ever replaced a tank similar to this?
    We talked to our local Freightliner dealer and they said the metalic replacement surge tank will run about $750.00 plus labor to replace. I'm fairly mechanically inclined, so this one doesn't really scare me, but I didn't know if I need to do any major bracket adjustments. I don't have ready access to grinders or welders.
    Let me know your thoughts. Thanks! Happy Camping! - Eric --
  • I've replaced a tank that is exactly like that. It's really fairly easy. On mine, it bolted right up.
  • That's the same as mine. The Freightliner replacement is $130.00 and pretty easy to replace. The mounting brackets are not exact, but if you are handy you can remake the existing brackets to work.
    http://s467.photobucket.com/user/gatordave48/media/IMG_0332_zps1651604e.jpg.html
    http://i467.photobucket.com/albums/rr38/gatordave48/IMG_0331_zps36cdb17f.jpg
    http://i467.photobucket.com/albums/rr38/gatordave48/IMG_0330_zpsd11ccba2.jpg
    You can see where I had to extend one hose.
    Good Luck
    Dave
