DraginRat
Dec 08, 2014Explorer
Couple of questions aboutg air system on class "A"
We recently purchased a 2002 Holiday Rambler Imperial through a "consignment" dealer.
While we are generally happy with the coach overall, there were a number of issues.
One of the bigger issues was the air suspension and leveling system was totally trashed. I spent a lot of time on the web learning many things about the coach in general, and the HWH air system in particular.
I pretty much have the air suspension and leveling system back in order, but while many documents I have located tell me how to adjust ride height, there is absolutely no mention of what ride height should be, how to determine what it is, or what it should be.
Also, while putting the leveling system back together, I noticed that the air dryer has been removed from the system. the air dryer (Meritor Wabco system saver 1200) is present, but has been disconnected. Someone connected the line from the compressor directly to the line to the tank with a brass nipple. The inlet fitting had been broken off in the inlet port of the dryer unit, but that was very easy to remove. It appears to be a very simple system, basically in, through the filter, and out to the tank. I assume I should replace the filter canister, but other than that, is there something I should be checking?
Also, how long should the air pressure last once the engine is shut down. Ours drops from 120 psi to about 90 psi in about an hour. Is that normal.
Thanks for any help you can offer
Ken Gasbarri
Ken Gasbarri
