dougrainer
May 30, 2016Nomad
1BryNelson wrote:
Wow. Gaskets and seals never leak. 30 yrs of limited expierence, Boys in the Navy thought me to expect the unexpected. I solved my hydralic jack leveling problem by replacing fluid, go figure.
OK, you want to be a pain. Who said anything about Gaskets and seals? WHAT was your problem that a fluid change fixed? I assume you have PG jacks from your post having a Fleetwood Pace Arrow. Where in the Navy do they use RV Leveling Jacks? Must be some funny looking Ship. ALL Hydraulics are not the same or have the same design parameters. As I stated, I have NEVER seen or had a problem on a Hydraulic RV system that pointed to or needed a fluid change that would fix a problem. Now, if you HAVE contaminated fluid, then yes drain and flush, but in he real world, getting ALL the old fluid completely removed will be a PIA for most systems. That means flushing the lines and draining the reservoir which is NOT an easy job. IF a Seal or Gasket leaks on a RV leveling system, THAT is not going to contaminate the existing fluid. The ATF in the leveling and slide out systems does not have gears and such to wear and contaminate the fluid, so if you want to change the fluid, go ahead, but it is a waste of time. Doug
30 years of limited experience???? I estimate I have worked on in excess of 500 leveling systems, and have FIXED every system I have worked on. Doug
