turbojimmy
Apr 04, 2014Explorer
Somewhat unrelated: the left rear window on my Allegro is letting water inside. I noticed that the rubber seal on the outside has a "creeping" seal in the corner, where it is leaking (looks like a rubber gasket pressed into the frame, all around the window). Is this why it's leaking? Or is there some other seal or drain that I should be concerned with?
