Hank_MI
Apr 06, 2014Explorer
mike brez wrote:
For dual pane windows with creeping seals Dave Root sells a kit Here
I think you're talking about a different problem. I believe the OP is referring to the rubber seal on the outside of the window, particularly the sliding half. It's a press fit into the frame. They shrink with age and pull in at the corners.
Pull the seal loose at the top where it ends and around the corners to the bottom. Then press it back in working your way from the bottom corner, to top corner and around. It may come up a little short at the top end but it's the side and bottom that you want sealed good.
