Hank_MI
Apr 06, 2014Explorer
turbojimmy wrote:
Somewhat unrelated: the left rear window on my Allegro is letting water inside. I noticed that the rubber seal on the outside has a "creeping" seal in the corner, where it is leaking (looks like a rubber gasket pressed into the frame, all around the window). Is this why it's leaking? Or is there some other seal or drain that I should be concerned with?
May be the seal, pull it loose and fit it back into the corners. Also check the drain/weep holes in the bottom of the frame. They get plugged with dirt, bugs, etc. and won't drain. The water backs up and flows into the inside of the window.
