superk wrote:
Hmm... after i got the cruise working, that was to be my next topic. My overdrive button does nothing. When I push it, the OFF does not light up as it is supposed to.
I thought that when the vehicle experienced transmission issues the OD OFF light is supposed to flash?
This has happened to me. The tiny wires at the base of the shifter got pinched in the shifter's pivot joint. I used some telecom splice connectors for a temp fixed, and then a body shop replaced it after the broke the end of the shifter all the way off while doing some paint work.
But... consider you have non-working cruise control too, I would also make sure the steering wheel connectors are all connected! I believe cruise and OD run through one connector, and airbag runs through another. Does your horn work?
