doubleG
Mar 04, 2014Explorer
Hi MM,
Bitter cold here, but managed to get some pics to send to Cummins. It appears I sprung a leak on the fixed steel line coming out of the air compressor. Looks like corrosion and at the point where the trans fluid fill tube was wire tied to coolant. We don't travel much in snow areas but do rinse after. This appears to be a place where either road salt/moisture has been the reason line corroded. Will fix and relocate tie off of trans fluid fill tube.
Thanks,
Dan
Thanks,
Dan
38,766 PostsLatest Activity: Jan 10, 2026
