moisheh wrote:
Access is dependent on your unit side V rear rad. On mine it is very easy to open the hatch. It is not in the floor under the bed or in the closet. I opened it up but the mechanic was able to climb into the engine compartment and reach. You need a skinny mechanic. There is one other possibility for your problem. When they removed the filters were they full? Are the thick o rings installed? On mine there was one filter mounting flange that was not machined straight. Don't know how it worked for 7 years. BTW there is a new improved filter . I am sick today so cannot get it but hopefully will find the # tomorrow. If the only code is that 559 Cummins has a whole list of things to check or replace. But I would suggest to just do the things I did. Anything else is going to be mega bucks. Do you have those plastic fuel lines? Could one of them have rubbed on something and made a pin hole? Please keep us posted. ON EDIT: What brand of filter are you using?
I have side radiator but access on the fuel rail side of the engine looks tight. To access top of engine, I have to remove the two wardrobe doors (have to remove bottom track to remove access panel in floor) and raise the bed.
Whenever I have removed my filters, they were full of fuel. My primary has 1" threaded stud and that filter uses the center rubber o ring. My secondary filter head has 7/8" stud and it is pretty short and there is no center o ring. If you try to put the o ring on that stud, there is not enough thread left to get the filter on.
The large diameter line from the tank to the inlet of the primary filter head appears to be a hard plastic. The line out of the primary and both lines on the secondary are some sort of nylon mesh wrapped lines.
I am under the impression it cannot be a bad lift pump since on our engine the lift pump only runs briefly, then goes into a bypass mode and a mechanical pump takes over.
I do remember my local Cummins shop telling me the diagnostic time and effort related to the 559 code was lengthy and expensive. I certainly don't want to tell the mechanic what to do but I do plan share your experience with him. I will be at an independent shop so not sure if they have the full access to all things related to Cummins.
