- HarleyDave1Explorer
I have an 03 escaper. Same issue. Still have not found fill tank. Pumps are behind steps. Any other places to look for tank? Thanks !!
- psherlandExplorerI found the pump but I haven't located the reservoir. I appreciate your suggestions though.
- TugCEExplorerMy 04 has it mounted on the Driver's side down low. One thing, do not add fluid unless all of the jacks are retracted.
- Some of the FR motorhomes 20 years ago installed the LCI pump assbly in 2 places.
1. BEHIND the entry step
2. Drivers side middle outside access door compartment UNDER a black plywood cover Doug - psherlandExplorerExcellent intel. I'll try listening for the pump with my wife's help this evening. Thanks!
- wa8yxmExplorer IIITwo suggestions... Front and center low (like frame rail level)
Have your partner operate the system LISTEN for the pump. it's about .. Bolted to the pump.
38,774 PostsLatest Activity: Apr 26, 2026
