wa8yxm
Nov 15, 2015Explorer III
Switch is the problem. Here is a procedure that MIGHT fix it.
REMOVE all 12 volt power. You do not want power to the switch,, Easiest way to do this is "DISCONNECT (Store mode) and disconnect.
Operate switch like 50 times.
Restore power.
NOTE: I can not guarantee this will work (The problem could be in the wires or the module) but if it does not work your FREE is hearby cheerfully refunded.
And if it does work.. The charge is a post reporting same.
Restore power.
