rudedogfire's avatar
rudedogfire
Dash heat only blows cool air
I just bought a 1998 Newmar Mountain Aire with a Chevy 454. I turned on the dash heat, and it blows cool air. The air conditioning works great. The blower also works fine. Just no dash heat. Engine temp. is a constant 165. I tried to locate the heater core, to see if the controls were disconnected, but couldn't find it. Does anyone have any suggestions?
  • Also check the coolant control valve that most likely on the outside of the firewall from the heater core. I think others have had problems with this valve not opening or closing.
  • First of all, I am no mechanic by any means. But your problem could have to do with the vacuum system that switches the airflow from heat to vents, to defroster etc. If that is your problem, then when you reset your control from say vent to heat it is not switching the vent internally. I had this problem on a GM passenger car once. Just guessing. Good luck!
  • Flush cooling system, make sure heater core isnt bypassed. Make sure also that coolant level is correct. start engine cold with radiator cap off and watch coolant level. see if it drops when thermostat opens and then add proper coolant. Also be a blockage in heater core or a collapsed hose.
