stugpanzer
Oct 26, 2020Explorer
time2roll wrote:
Stay away from GELL. Need special charging to limit voltage and amps.
Get AGM if you want no maintenance. I recommend Lifeline.
Otherwise a couple flooded batteries from Costco is a good value.
Or is there something special we should consider in the recommendation? Two batteries seems light for such an RV but maybe you are almost always plugged in.
thanks for the tip. This coach is set up for two batteries and yes, we do stay plugged in most of the time.
