Bill22 wrote:
Do deisels generally require upgraded suspensions in order to handle good on the road? I have a 30ft gas and had to put $4500 into upgraded suspension in order for it to be safe to drive.
As a direct answer, and with all politics and whining aside, the chassis that a diesel RV is built on will not require upgraded suspension in order to handle well. In most cases, there are not even upgrade options available for this kind of RV. My first RV was a diesel pusher but was also a very low end coach and it did not handle well either. It was under powered and on a chassis with 19.5 tires (early 1990's). These just don't really exist any longer in the current RV market and you should expect excellent ride and handling from a diesel powered RV. If you want the best diesel ride then you will want to buy one with a tag axle as the ride and handling is determined by the chassis and not the power source.
