DryCreek
Apr 22, 2017Explorer
Will the CHF alter suspension geometry?
I believe the answer is YES in - with a caveat. I think that it depends on the GVWR for the F-53 chassis it is performed on. My Winnebago 29R is on the Ford 18K lb. GVWR chassis. When I moved the stock front sway bar links to the back hole the bar and the links were nearly in line, and my suspension travel was shortened somewhat. I went with the Hellwig 7962 adjustable sway bar links and set them to maintain the OEM geometry. Suspension travel was returned to stock parameters. Plus, I could take the front stock sway bar links and use them for the CHF on the rear. The front links are exactly one inch longer than the stock rear ones. I didn't want to get in a bind and have the upper end of the sway bar possibly contacting the VSS mounted in the top of the differential housing.
It may be that the F-53 chassis rated for higher the GVWR have different sway bars or end links. Or maybe the slight differences between chassis runs through the years? Just kinda' grasping at straws there - as I've seen posts where some have had no change and others (like me) did.
