burlmart
May 17, 2014Explorer
Did I just fix my front end sway bar?
After doing work on the overcab noise makers, we were surprised to hear what sounded like a jostled stack of lumber. I thought it was from overhead, but Martha thought it was from below. I found a shim missing from that big curved bar that is fastened to the frame w/ two hard rubber shims held on w/ semi circle clamps. The ends of the 1+" dia bar attach to the tops of vertical rods that are fixed to the tire pivot arm(?).
Is this big curved bar the anti sway bar?? What does it do, exactly. Seems to almost be designed to "float", to act non-rigidly.
With the missing shim, that big bar could hit the frame close above it, and that might be the noise maker. I do not know how long its been missing - recently, I hope.
So I wrapped about 18" length of a piece of bicycle tube around the bar and installed its hoop clamp.
Will this do the trick, or must I locate a bona fide chevy shim?
The other shim is brittle, cus a little piece of a rib of it broke off in my fingers.
Thanks
Thanks
