milkman41's avatar
milkman41
Difference in levelers
I have noticed that larger DP models have hydraulic levelers, less large (39 & below) have electronic levelers. Is there anything to be aware of with electronic?
  • I have had continuous problems with my Electric Power Gear levelers.
  • gatorcq wrote:
    Atwood developed a electric levers system. The know problem was over extending breaking the weld plate. Atwood redesigned the lever, but did not stand behind the faulty weld joint. The new design counts the revolutions and sends it back to it's home position. Thereby not breaking the weld
    Do you know what year they made the improvement?
  • Gatorcq, I've never seen an Alpha See Ya that wasn't mostly white. Very nice looking! Did you have it painted or is it factory?
    Safe travels,
    MM.
    PS. Sorry for the off track note.
  • Atwood developed a electric levers system. The know problem was over extending breaking the weld plate. Atwood redesigned the lever, but did not stand behind the faulty weld joint. The new design counts the revolutions and sends it back to it's home position. Thereby not breaking the weld
  • I believe the pad dimensions are more important, small footprints will dig into parking surfaces. I am noticing more RV parks with asphalt surfaces, requiring block under the levelers.
    Fred
