wny_pat wrote:
tropical36 wrote:
I imagine it takes some new hole drilling, correct? Also, how is it turned this 360 degrees and from inside the coach also?
No, you can mount it right on the old crankup mount that the Winegard Sensor was mounted on. That is were I mounted mine.
There are two types that RV Jack sells. You are talking about the one that clips onto the head of the old Winegard unit. I ruined the crank mechanism in my old antenna, so the old antenna needed to be removed.
I bought the one that mounts directly to the roof because I'm tired of worrying if I left the antenna up. The RV Jack roof-mount antenna wouldn't go exactly where the old one went. I had to re-locate mine because the antenna was up against the A/C unit. The hole would have been too small anyway.
I removed the old antenna, patched the hole, drilled a new larger hole a few inches away so that the new antenna would clear the A/C unit.
