erniee
Dec 05, 2013Explorer
Norm & Deb wrote:
Coach has two slide outs, both on drivers side.
taking out the furniture relieves you of a lot of headaches when you have to work around objects.
Your floor is made up of OSB- oriented strand board. If you get a multipurpose tool for any demo, that will make this project easier. Take an ice pick in the affected damaged areas, after carpet and whatever else hard surface you have removed. If you jab the pick into the floor and it penetrates with ease, move a bit further away to ascertain how extensive the damage is. Then you can start replacing the OSB.
38,783 PostsLatest Activity: Sep 10, 2026
