Tonijim's avatar
Tonijim
Disconnect Jensen Dash Radio
While I'm in a posting mood - does anyone have a suggestion on how to temporarily disconnect a Jensen dashboard radio so it doesn't draw down the engine battery during winter storage? The mtorhome is a 2010 Thor Freedom Elite 31R. Is it as simple as removing a fuse, or is a disconnect switch the only way.
Thanks
Jim
  • If it is indeed connected to the chassis battery, there would be a fuse in the chassis fuse panel for the radio standby (and possibly some other things). It may even be labeled sensibly if you're really lucky. Note that this may well not be the main fuse for the radio, since the memory line is a different connection than the main power (and typically the main power is switched with the ignition).
    Disconnecting the battery negative cable would be the simplest and surest approach, I think, and also eliminates any other parasitic drains.
    Do check that the radio circuits are actually powered by the chassis battery. Mine is wired to the house battery, and some have a switch to select which battery is used.
  • If you can get to the back of the radio you should find a plug going into the radio. Should be able to unplug that and then plug it in next year.
