Jim
Aug 12, 2016Explorer
Crawl under there in a way that the steps can't crush you, disconnect the electrical connector, unbolt it from the frame, put it on your picnic table, open everything you can and clean everything. Even the motor can be serviced and cleaned up, good time to check the bushing. Often just a really good bench cleaning, contact polishing, joint lube, and gear greasing can restore operation and give years of life.
Take some pictures and show us how it goes.
You could maybe even cut the bottom step off if you want, as long as the mechanical design allows it. Never heard of that being done, so you might be the first.
38,708 PostsLatest Activity: Mar 05, 2025
