rgatijnet1
May 08, 2014Explorer III
My emergency and non-emergency windows are exactly the same and exactly the same size and operation. The only difference is that because at least one window has to be designated as an emergency exit window, the manufacturer installed a red handle/lock. If you compare the red lock with your other window locks, you will see the only difference is the color. Basically I have three windows in my coach that are the same size and could easily be used as an emergency exit. If needed in an emergency, I can use any of the windows and will not make it a priority to go to the one with the red lock.
