jorbill2or
May 08, 2014Explorer II
Effy wrote:rgatijnet1 wrote:
My emergency and non-emergency windows are exactly the same and exactly the same size and operation. The only difference is that because at least one window has to be designated as an emergency exit window, the manufacturer installed a red handle/lock. If you compare the red lock with your other window locks, you will see the only difference is the color. Basically I have three windows in my coach that are the same size and could easily be used as an emergency exit. If needed in an emergency, I can use any of the windows and will not make it a priority to go to the one with the red lock.
This isn't true. Both my emegency windows are hinged at the top and have levers. None of the others do.
Ea Rv is different ... If the sliding window in YOUR rig is large enough it can be a standard window. If the opening portion is not large enough the whole window can be made to be opened in the outer frame .. Thus the upper hinges and red locking handles at the bottom Know your own system but others are different normally one exit in bedroom and main living space.
