kratedisease's avatar
kratedisease
Does A/C turn off automatically climbing hills ? Ford F53
I was climbing a long hill in the mountains today when I noticed that the A/C unit stopped blowing after a extended climb but turned on again after I stopped climbing and the RV up shifted to 3 or 4th gear. Even the fan blower stopped blowing. When I reached the top of the mountain I manually shut the system off with the switch and then switched it on and it restarted and worked fine the rest of the trip.
Is this normal ? I have an older F53 chassis, a 2000YR Hurricane by Thor
If so is this a power save feature that is programmed into the ECU ( electronic control unit ? )
Or is this just the system becoming overloaded and shutting down ?
Anyone else experience this ?
Please advise , thanks
