cooper3197ExplorerApr 21, 2014Dometic FridgeCan I plug my Dometic Fridge directly into an outside outlet that is not connected in any way to the camper or is there a reason that I would have to run it through the camper outlet. Thanks.
pianotunaNomad IIIApr 21, 2014Hi,The fridge only draws about 325 watts. The fridge must have 12 volt dc power to operate the control board.You may be better off moving the water heater or the converter to a separate auxiliary shore power cord (or even do both as I did).
Related ContentDometic 2-Way fridge repair issuesDometic Servel RGE400 fridge too coldDometic fridge woes.dometic Fridge repairDometic fridge RM2652 tripping thermal sensor
