Can I plug my Dometic Fridge directly into an outside outlet that is not connected in any way to the camper or is there a reason that I would have to run it through the camper outlet. Thanks.
wkc5053 check on You Tube there may be a video for your model. AsI recall when I did mine (new cooling unit) It's just unplug the 110 plug and the 12 volt pos. and neg wires. I was doing it by myself so I took the doors off to make it lighter and easier to handle. Just laid it on he floor of the MH and did the replacement.
