Can I plug my Dometic Fridge directly into an outside outlet that is not connected in any way to the camper or is there a reason that I would have to run it through the camper outlet. Thanks.
As the harmonious fish (PianoTuna) said, you need both 12 and 120 volt, (12 runs the devices computer controller) if you plug JUST the fridge in batteries will provide 12 volt for a time,,,
If the problem is with the 120 volt stuff in the coach and the converter is still plugged in and working.. GO FOR IT.
