rubycreekted's avatar
rubycreekted
Dometic power awning constant Boop-Boop-Boop. Help please
I am camping beside a 2006 vintage coach with subject awning and symptom. The ladies do not have a owners manual. It has a box about 6 inch by 5 inch with a rocker switch that says in-out or up-down. I took the cover off this box and checked the fuse under the cover. The beeping stopped when the fuse was removed but started again as soon as I put the fuse back in. Can anyone please tell me what the beeping is trying to tell us and what may be the problem. THANKS, TED
  • btilfan wrote:
    2006 is vintage?
    EXACTLY what I thought. Mine is ancient, it's 3 years older than that. Thanks for the reminder, that I'm old, retired, and broke....
    hahahaha
  • Jesse_C wrote:
    Did you see a toggle switch on the black control box for the wind sensor? If so, turn it off, the beeping should stop.
    No I didn't know about the switch. I will check tomorrow. THANKS ALL,, TED
    The beeping is an indication that there is a LOSS of communication between the control box and the Wind sensor. As he stated, on the side of the box is a phone type cable and the toggle switch. Turn the toggle OFF and the beeping should stop. Doug
  • Did you see a toggle switch on the black control box for the wind sensor? If so, turn it off, the beeping should stop.
