tmmar's avatar
tmmar
Dometic Refrigerator Temperature slide control
The thermistor that is in the white plastic temperature slide control inside the refrigerator on the cooling fins came out of the plastic slide. Does anyone know where in that slide the thermistor should be placed and how to keep it from coming out again?
Thanks,
Tom
__________________
1 Reply
  • The bulb end of thermistor (tip) should just protrude from top of clip.
    They just slide in clip.
    Clip goes on right fin.
    Move the clip up for cooler temps in fridge section
    Move the clip down for less cooler temps in fridge section
    If clip doesn't hold themistor use a dab of silicone to hold it in clip
    DON'T get any on tip.
