hotdog26's avatar
hotdog26
Dometic RM 1350 Fridge cooling question
The fridge seems to work correctly on both gas or electric. Here's my question, the temp on the eyebrow says the fridge is at 33 deg. but the thermometers in the fridge read 40 and freezer reads 3 deg. So what's the problem the thermistor, eyebrow board or where is the temp sensor because I think the temp should be a bit colder. accepting all suggestions and ideas.
  • The freezer has no temp sensor. The temp sensor in your model is the Evap fin sensor.; The evap fins will be 10 degrees COLDER than the actual temp, so at 40 degrees the refer is within spec. The ideal would be 23 to 27 degree readout which add 10 degrees to that reading. Are you at MAX cold (5)? Doug
