- charwanExplorerWell first I printed the manual for the Kwikee steps. I have an 04 and looking at the parts sheet it takes 909510000 which 90% do. All I had to worry about the color of the door switch, which mine was black. Having ordered a controller already I cut the wires going to the motor so I could use the connecter in the motor to verify what that the motor was good. By reversing the wires I could work the motor and gear box back and forth. My steps worked smoothly with the motor off so no trouble there. The Kwikee service manual lists all the parts for all of their equipment but doesn't say any thing out testing or problem solving.
- down_homeExplorer IIHad that happen a few times. They tried to come in. Dirt etc had gotten onto the mechanism and the step links or whatever the proper term is.
It was hard to get underneath with steps out but I did and leaned the motor arm and bearing good with silicone spray wiped it and sprayed it had wife close the door and open it and sprayed and wiped it a bit more before finally spraying it with steps out again. Let it dry. The step arms or links always get washed of course. The nylon bushings don't want grease neither does the motor arm and bearing. Grease attracts and holds dirt and grit.
There is another step manufacturer that makes almost identical unit but with sealed bearing areas. I looked it up once and posted here but a long time ago.
Switches need cleaning just a bit sometimes. I carry a spray can of electrical contact cleaner.Too much will actually inhibit contact if left to dry before closing too long.
However the motor is Ford window unit. Many times there have been discussion about replacing it.
Really be handy if site maintained an index of problems and fixes and parts. - GjacExplorer IIIWhat year is your MH? If too old you may not find a replacement controller. If you take the cover off the controller and slide the board out, you will see a couple of relays inside. Look for melted plastic on the case of the relay, that is the one that needs to be replaced. If you have good soldering skills or know someone that has it can be replaced for less than $4.
- charwanExplorerTried all the good advice you fellows gave me and I have determined that it is the controller. I took the gear box and motor off and put 12 volts and it worked. I checked and it has 12 volts too it and the switch has 12 volts. No voltage coming from the controller. So I guess I'll order the controller. Thanks for all the info and advice it helped me a great deal. CharWan.
- Blaster_ManExplorerHave they been lubed recently and do you have good 12v power?
- BusskipperExplorer
charwan wrote:
My door steps just quit coming in. Had no trouble with them and now on the road. Any ideas would be appreciated I'm on the road..
Check the Ground connection.
Check the Magnet.
Good Luck, - CampinghossExplorer IIIf you have power to the motor before you spend the dollars on a new one, take it out and apart. I was told the motor was bad but it was just the plastic bushings. I think it was around 6 dollars to repair it. I don't know what type steps you have but I expect if you have power to the motor it is hanging up due to the bushings.
- wa8yxmExplorer IIIKwikee uses common window riser motors. both Ford and GM depending on the step model.
First... You do not want to be anywhere the steps might go to when the door is opened and closed,
But try this, "Tunk" the motor.. I use the HANDLE of a hammer (hold the head in my hand) a few times then try opening and closing the door again.
1: "The switch by the door"
Old controllers it would indeed lock the steps out or in
new ones lock out only..
Ignition overrides in both cases so if the engine is running and you close the door it SHOULD close.
2: There is a magnetic reed switch in the door jam. Normally about 1/2 inch from the bottom on the latch side where the screen sits.. For some reason the magnet (Which is in the screen door) was not getting close enough. I had to bend things a bit.. Then it worked. - GottahaveitModeratorListen to what Doug has said many times..we did and yes it was the Motor. Just order a new one from amazon and fixed it once and for all. It's a easy job to do. We had the motor shipped to the Elks Lodge we were staying at and did it at our spot. So glad for the help :)
- D_E_BishopExplorerMight help to know what brand of steps,model and year.
If they are Kwikee, check the ground, fuses and the on/off switch.
If all is okay, as per Dougrainer, with the engine running, have someone close the door as you tap the motor. If it starts operating, you have found the problem.
Click on the following,Click here.
Use common sense and keep fingers out of the mechinism and your body free of step travel.
You need to disconnect the two wire cord to the motor and remove the three bolts that hold the motor to the gearbox and linkage. Easy to R&R.
If you download the step operators manual, it will give you lots of info. Need the series number and year of manufacture to get the right manual.
