Medico wrote:
The other problem, which has been mentioned briefly a couple of times, is that a gas motor will have to rev much higher to get up that same hill as a DP. That is one reason why oil change intervals are more frequent with gas engines. They have to work harder to accomplish the same thing. Generally this is not a problem if you do good maintenance and the gas engine has lower miles. That same gas engine, as the miles begin to accumulate might need major work much sooner than a diesel engine.
In addition, as has been mentioned, most gas chassis start out much shorter and need to be extended to accommodate larger coaches. The chassis/gas combo was designed and rated for the shorter chassis. Put a longer chassis on it without changing something else (gear ratio for example) and you will shorten the lifespan of the chassis, including the engine.
Medico, I'm a fanboy of diesels but I don't agree with most of that statement. The V-10 is made to work, there are folks over on the class c forum who use this engine for work purposes and have over 500000 miles without significant problems. The e-450 and the f53 chassis are very well designed and are really workhorses for the gas side.
No they won't handle a 60000 lb Coach. But I can tell you that over the lifeccyle of a typical v-10 versus a venerable Cummins (which I love), the v-10 will be cheaper to operate hands down. None of that means I don't like diesel power, I do! And I will switch to a diesel pusher in the next few years because of air ride and comfort as I retire.
Most of the frame design issues have been put to rest over the years and the new Class C's are very capable, Forest River now has a 7500 lb hitch rating.
In my opinion it's a complicated choice, layout , comfort, price point you can be comfortable with, and then drivetrain selection knowing diesel will cost more not just for the fuel itself but on odds for long term maintenance.
