Raymond_Quintal's avatar
Dec 29, 2014
drivers door panel removal 2001 E450,
The mirrow on the drivers door is about to fall off my 2001 E450 c class motor home. It is a power mirror with a heating eliment. it appears I have to take the door panel off to get to the mirrow attachment bolts. I removed the only two screws I could find, one AT UPPER corner by mirrow controls and one at lower left corner of door panel. I tried to remove door panel by pulling out to release any clips with no results. it appears that there are more screws or some type of attachement in center of door which I can not find. anyone know how to remove the door panel or thighten the mirrow. Thanks
  • Try searching on youtube for a demo video. I found one for my F150 when I had to replace the window motor.
  • Look under the door handle or inside the handle. The part you pull on to close the door.
  • I would recommend that you get a "Haynes Repair Manual" for a Ford Super Duty of the year range that you have. There will be a section in manual on door panel removal.
