jpratt2's avatar
jpratt2
Dry winter parking
We have a 29' Bigfoot class C and plan on keeping it parked for the winter in our driveway, which is gravel.
I'm concerned about rust and mildew issues. The surface drains well, but the water table here is high during the winter and everything under the rig will be very damp until spring....no puddles or standing water though. Paying for covered storage and/or paving the drive are out of our budget at present.
Question: do any of you use some sort of a moisture/vapor barrier to park your motorhome on to reduce the ground moisture?
Thanks!
  • If there's no standing water then it seems you're only concerned is for the tires and you could either raise them off the ground or put them on some pressure treated lumber concrete blocks might even be better.
