RVNewbie1972ExplorerApr 29, 2013Dually Rims- Can you mix steel with Aluminum?Hey Everyone- I have a 1993 Ford E350 dually which houses a 1994 Eldorado. One of the outer rear rims has taken a beating on the outer bead and needs to be replaced. Currently, all rims are steel o...Show More
DakzukiExplorer IIApr 29, 2013That is the standard setup for Sprinters with alloys. The factory studs are not long enough to mount two alloys on the rear.
Related ContentAluminum RimsAluminum RimsAluminum Rim only rated for 60PSI2006 Dually Rims22” rims vs 18” rims
