RVNewbie1972ExplorerApr 29, 2013Dually Rims- Can you mix steel with Aluminum?Hey Everyone- I have a 1993 Ford E350 dually which houses a 1994 Eldorado. One of the outer rear rims has taken a beating on the outer bead and needs to be replaced. Currently, all rims are steel o...Show More
jgorm1ExplorerApr 30, 2013Yeah, I run 4 alcoa's and they say that you have to run steel on the inner duallys, probably for the stud length.
Related ContentAluminum RimsAluminum RimsAluminum Rim only rated for 60PSI2006 Dually Rims22” rims vs 18” rims
