Captjack
May 01, 2013Explorer
I am pretty sure you don't want to goop up the lugs and lug nuts with anti-seize. As I understand it, when you torque up a bolting set to high levels, you get plastic deformation and good metal to metal contact. If you torque up a anti-sieze treated set to the proper torque, I would think that it would be more likely to loosen under cyclic load. FWIW, Jack (Electrical, not mechanical engineer)
38,782 PostsLatest Activity: Sep 10, 2026
