mfox20 wrote:
Just FYI in case you have a failure.
As Doug mentioned in an earlier post, the 4 button units are no longer made. There are several sellers on Ebay that offer rebuilt units starting at 125.00 with exchange of your unit within 7 days of receiving the new rebuilt one.
Mine failed several years ago and I was able to find a gentleman online that did the rebuilds. I have not had any issues with the rebuilt unit. They basically recondition the 4 buttons and the on-off switch.
You are better off upgrading to the 5 button tstat. You buy 2- 5 button upper control boards(if you have 2 units) at $95 each and a 5 button tstat at $85. $275 and you have NEW control boards and a NEW tstat that has the ZONE button. They also come with NEW freeze Thermister's which are better than the old bi metal freeze sensor, PLUS, IF you have a Heat Pump on the 4 button, the NEW freeze Thermister will work with a Heat Pump. The 4 button Heat Pump had NO freeze Sensor as the Bi metal could not function when in Heat mode. Doug
